Parallax SX Design Contest in 2006 - Setting up a Schedule!
Dear SXers:
The rest of 2005 and 2006 will be an exciting year for the SX, I assure you.
Once again, we are planning for a design contest. With the SX/B compiler, all the neat development tools (SX48/52 Proto Boards, Guenther's SX MultiBoard, low-cost SX Tech Tool Kits), and skilled participants on this forum it should be quite a success not to mention an increase in the prize money.
For our last contest we underestimated the amount of time you needed to design your proejcts. We initially provided four months but it was extended to seven months by the time·the contest·ended. Which brings me to the area where we request your input.
Is six months enough time for you to design another neat SX application, provided most of this time occurs in the middle of winter?
Sincerely,
Sincerely,
You know engineers... I don't think any of us like to be hurried, and there's always that "one more option" to needs to be design in. If you had an option for 12 months most of us would probably choose that [noparse];)[/noparse]
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"One experiment is worth a thousand theories"
While I agree with Bean that it's always nice to have more time for more features (really, software is NEVER "finished"), I believe his 12 month suggestion is one I would not choose.
I believe 6 months should be enough to do any small, and many lager projects. If the time provided is too long, interest will fade, and that's not useful for those who choose smaller projects and have their work finished earlier.
Also, if you have much time available, the projects chosen will likely tend toward the larger size, and that may preclude newer/beginner users from making an entry.
If I had my way, I would suggest two simultaneous contest segments, each judged separately; one with a 3 or 4 month window, and the other with a 6 month window. That way newer participants will have more of an opportunity of making a decent showing, as the more experienced are more likely to chew off something bigger.
As an even better idea, although it will be more up-front administrative work, perhaps you would consider a multi-category (3 or 4 ?)annual event with minimum requirements per category, and every subsequent year a participant enters, they are forced to move up one level of difficulty. That way you are not pitting experienced users against newbies, and still keep the whole thing challenging and informative (presumably the principal purpose) for every one.
Perhaps the judges could set the expectations and standards, and manage this effort for you.
Anyhow, just my thoughts.
Peter (pjv)
Post Edited (pjv) : 8/15/2005 6:51:10 PM GMT
I wasn't suggesting that Ken make a 12 month contest. I was just pointing out that I think almost everyone is going to choose the longer lead time. You right 12 months is too long and interest will fade.
Bean.
Jon Williams
I should get substantially closer to a result this time, now that I have working development tools [noparse]:)[/noparse]
bongo
John J. Couture
San Diego Miramar College
Ryan
Ryan Clarke
RClarke@Parallax.com
