Questions about connecting a 4 x 4 matrix keypad to I/O pin of BS2p40
Hi
Anybody have tried interfacing such a keypad to a BS2p40 I/O pins before? If so, what keypad scanning technique did you use? I am trying to implement a "Walking Zero" continous polling keypad scanning system with the keypad that I'm using. I'm also wondering if theres any need to connect the rows and the columns of the keypad to ground, while connected to the I/O pins?
Gabe
Gabe
jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=171969
This way the keypad data is serial, and my BS2's, can get to it when they have a chance. (Window of aprox 50 ms, should be plenty of time. [noparse]:)[/noparse] )
Knight.
·· I have used the E-Labs chip many times for keypad decoding.· Nice to use 2 pins instead of 5 or 8.
Forrest,
·· I have also used the same concept as in the N&V article you linked.· In fact, using old C=64 keyboards we used to do 8 X 8 decoding of 64 keys using 2 8-bit I/O ports (Pre BS2 days).
csavage@parallax.com
