Need some help With Bs2 OEM/Sumo Bot
Hi guys!
well I am now making a board to hold my bs2 and press buttons/connectors for servo's and battery etc. I am using Proto Board to do this, but I am having some trubble deciding what I/0 pins to use with what.. because I think I am going to have to use some ones mini sumo bot program ( because the guy who was going to help me program mine decided to make something eles with his bs2 oem) so if I use a premade program .. all of the pin configurations will be messed up.. and I just don't know what to do.
It's like I need some one to tell me what I/0 pins to use with what... and then give me a program to match
... I think I am in over my head with out my programmer but I still want to finish building my mini-sumo.
If some one could help me out that would be great!
thanks guys!
_Mike_kd7lax
Visit my website @ www.kd7lax.com- Devoted to ham radio
... I think I am in over my head with out my programmer but I still want to finish building my mini-sumo.If some one could help me out that would be great!
thanks guys!
_Mike_kd7lax
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
Post Edited (Dave Andreae (Parallax)) : 8/13/2005 1:58:38 PM GMT
I have the fallowing:
(2) QTI sensors ( they will be looking for the white line around the edge of the sumo Ring)
(2) Infared transmitters and Recievers ( to locate the other robot)
(2) Servo's
(1) Push botton ( for the 5 seconde Delay and power up)
Hmm thats all I can think of that runs off of the I/O pins.
As far as functions that i want it to preform:
To sence the white line on the sumo-bot ring and move away when it does.
Sence the other robot and rush forward when it does.
And when it does not sence a robot it will move in some sort of pattern on the sumo ring. (Eg, when ever it hits a white edge it takes a right turn.)
I think thats what I need it to do .
Let me know what you guys think !
-Kd7lax
Dave
Dave Andreae
Tech Support
Hmm ok I will try that manual..
Also I am going to buy the sumo bot tires... I was going to build my own but it looks like it will save me some trubble to buy them [noparse]:)[/noparse]
The "b" connects to the Vss The "r" connects to pin 9 and the "W" connects to pin 10, but what If I have 2 Qti sensors? do they both use the same I/0 pins? or are they seperate?
IF seperate what pins should I hook the seconde one up to?
thanks
·· You can connect the R and W pins to different I/O pins for additional sensors.· The B lines all go to Vss.
csavage@parallax.com
so now how do I hook up my IR Emmiters and detectors?
Also where should my QTI sensors be? on the scoop or before it?
Post Edited (Kd7lax) : 8/24/2005 8:44:37 PM GMT
Putting them 'under' the scoop accomplishes two things:
1. it casts a 'shadow' over their area, making them function better
2. puts them closer to the wheel so that tilts aren't so disruptive to their reading (lifting up)
Ryan
Ryan Clarke
rclarke@parallax.com
