Little Step U, changing speed during run?
Is there anyone who know how to change speed during run, when controlling a step motor with Little Step U?
For example: can I change speed when using command {H}, {J} or {G} during movement? Otherwise I have to stop the motor before changing speed!
What can I do to get around my problem, is there anyone out there who has had the same problem?
Regards // Johan
Regards // Johan
·· Aren't you still trying to make the speed change coincide with an input in the IP1 and IP2 pins?
csavage@parallax.com
The inputs IP1 and IP2 only stops the motor(depending on what command you drive the LSU in, {H}·listen to·IP2, {J} on IP1, {F} on both and so on..). They works like a type of emergency stop. I would be nice to·change speed with the IP pins but my question is if·the LSU is build to be able to change speed during run at all. Is it possible to change·only by upgrading the {A} command?
I have tried to contact the manufacturer, but they have not responded. This was only an attempt to reach out to other LSU users...
Maybe my wishes and expressions is confusing, but I hope this will clear things up..
·· By all means this is definately the place to get feedback from those people who know the product and/or have used it.· I just wanted to confirm your original question, since it slightly changed.· I hadn't realized you found that information out already.· Perhaps someone on here is a Little Step-U guru?·
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
kelvin
Your first option is more like it.
On one side I have my step motor controlled and driven by BSxs and LSU. On the other side I have “a sensor” that checks a signal. In the middle I have another controller that is doing stuff with the signal; this controller uses RS232 to communicate with BSsx. I want to move and control the motor in real time, lets take one example: The motor I running, if the signal is strong I want to speed up my motor, if the signal is week I want to increase the speed, ore if the signal is really bad I want to change direction. I want to ramp it up while running.
I can probably do this by step a small number of steps at the time with different speeds…
But that would not be beautiful.
Do you recognise my problem? Can you please give me an example on some creative coding, which makes this easier?
I will look into the remote state in more details, but i dont think it would do the trick.. we will see..
regards//Johan
kelvin
