The circuit uses LEDs with 1k resistors, since the Homework board has built in 220ohm resistors on the·I/O pins·I would change out the 1k resistors for ·470ohm resistors.· Since the LEDs are polarity sensitive you need to connect it as shown in figure 26.2.
If am I right it is writen in PBasic 1.0. You have to convert it!!!
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
'{$STAMP BS2}
'{$PBASIC 2.5}
DEBUG "Traffic Light Model"
DO
HIGH 10
PAUSE 500
LOW 4
HIGH 0
PAUSE 1500
LOW 0
HIGH 2
PAUSE 500
LOW 2
HIGH 4
PAUSE 500
LOW 10
HIGH 6
PAUSE 1500
LOW 6
HIGH 8
PAUSE 500
LOW 8
LOOP
Dave
Dave Andreae
Tech Support
