·· If that is the case (DEBUG Window Macros), then you simply click Add, Select the key you want from the drop-down box on the top right.· Give it a name, and type in the data to be sent.· When you're done you can save that list of Macros using the Save... button.
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Chris Savage Parallax Tech Support csavage@parallax.com
·· Macros are not supported in the BASIC Stamp Editor.
regards peter
bugg
Boe-bot: $229
Toddler: $249
Learning Google is your friend: priceless
