Convert hex to decimal
I need to convert a hexadecimal number to a decimal number, but can't figure out how to go about it.
I get seconds, minutes and hours from a DS1302 RTC chip via SHIFTIN, but the values are in hex, so I need to convert them to decimal in order to do decimal calculations with the numbers.
I've looked in all the help files, manuals and other PDFs I could find. Even a forum search for "convert hex" turns up dry.
Is this such a basic question that I'm the only one who is stumped by it?
I want to calculate the number of seconds since the RTC was reset. It's for an intervalometer with display, to be used with my Canon 350D camera for time-lapse photography.
Thanks in advance!
/Jonas
HIGH CS1302 SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]RdBurst] SHIFTIN DataIO, Clock, LSBPRE, [noparse][[/noparse]bytRTCSecs, bytRTCMins, bytRTCHrs] ' Here I'd like to convert the hex values from the RTC chip to decimal, so the following code would work wrdRTCSecs = (bytRTCSecs + (bytRTCMins * 60) + (bytRTCHrs * 3600)) LOW CS1302 wrdGoalSecs = 3240 ' Just an example decimal figure wrdSecsToDisplay = wrdGoalSecs - wrdRTCSecs ' The number of seconds to be displayed ' Display the counter on the LCD SEROUT pnLCD, conLCD, [noparse][[/noparse]conLCDTopHrs, DEC2 (wrdSecsToDisplay / 3600), conLCDTopMins, DEC2 ((wrdSecsToDisplay // 3600) / 60), conLCDTopSecs, DEC2 ((wrdSecsToDisplay // 3600) // 60) ]
Thanks in advance!
/Jonas
· decVal = bcdVal.NIB1 * 10 + bcdVal.NIB0
· bcdVal = (decVal / 10 << 4) + (decVal // 10)
Just a not on your code, though, you are trying to store seconds in a Word -- this is not possible because there are 86,400 seconds in a day (24 x 60 x 60) and that exceeds the limit of a Word (65,535).
Jon Williams
Thanks for the solution and the tip, but I was aware of the limit. I figure I'll put a GUI limit on 18 hours per interval, it should be more than enough.
How would one go about storing higher values? Is there an easy way to use a bit or a nibble to "extend" a word variable?
Thanks!
PS. Might I suggest a topic in the manual and the help file about conversions between the different number formats?
Jon Williams
