24c16
I've resently used a 24C16 for writting some numbers and then read them and display them.
I know that this may sound crazy, but I'm using a different type of stamp board, fully factioning with the PBasic compailer...(in fact it is a BS2 but the PIC and the memory·are seperate)
Now, the question is if i can use this memory without damaging the PIC.
To understand the whole thing it is like removing the memory of stamp BS2 module and replace it with the memory, with the programm following:
(The notes are written in Greek)
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
-Rule your Destiny-
Jon Williams
2048
Address...
Output.... 2047
Input...... $FF
Status.... $00
Errors..... Fail
Am I OK?
Thankfully, Provas
-Rule your Destiny-
Jon Williams
I used def.DATA to be sure that the·pic could read them and it worked!!!
The programm was a RTTTL file·shown at "What's a microcontroler".
I guess that in order·to be sure I must check it with large-scale programms.
Thankfully, Provas
-Rule your Destiny-
