resistor back
how do i know how big of a resistor back to use with a npn switching transistor circuit??? i usually use 2n2222 transistors with a 2200 ohms resistor back. but i saw in a nuts and volts(steroids for stamps) it said to use 390ohms. i usually use the transistors to switch multipul leds in series...
thanks for the help
thanks for the help
Beau Schwabe
IC Layout Engineer
i figured there must be a formula.
the load i want to drive is about 100ma and the hfe of the transistor is 200 so...
Ibe = Ice / hfe
ibe = 100/200
Rbase = ( Vsource - Vbe ) / Ibe
rbase= 4.4/.5
rbase = 8.8k resistor
right????
Just wanted to clarify....
100mA is .100 not 100
.100 / 200 = .0005
4.4 / .0005 = 8800 Ohms = 8.8K
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 8/10/2005 7:05:01 PM GMT
How would the calculation above apply to a MOSFET? I have an IRF7488, I'm driving 2W@9V (220mA) using a BS2 on the gate (Vsource = 5.0V).
Ids = 220 mA
Vsource = 5.0 V
Vgs = ?
hfe = ?
I've attached the data sheet for the mosfet, I'd really appreciate your help in understanding the MOSFET application to protect the BS2.
Thank you,
Phil
Beau Schwabe
IC Layout Engineer
which effects the overall response time of the MOSFET. Usually on this front, I take the recommendation from the application note on the MOSFET
since this would mainly apply to high speed switching and I personally don't do much of that.
By googleing, I did find a way to calculate RGS for use as protection circuitry" (towards the middle of the document)
http://focus.ti.com/lit/ml/slup170/slup170.pdf
Beau Schwabe
IC Layout Engineer
