16bit scaling
how do i multiply a byte by 10 and div by 64 in SXB?
the algorithm may be simplified because the denominator is 2^6...
If I lived back in the wild west days, instead of carrying a six-gun in my holster, I'd carry a soldering iron. That way, if some smart-aleck cowboy said something like "Hey, look. He's carrying a soldering iron!" and started laughing, and everybody else started laughing, I could just say, "That's right, it's a soldering iron. The soldering iron of justice." Then everybody would get real quiet and ashamed, because they had made fun of the soldering iron of justice, and I could probably hit them up for a free drink. - Jack Handy
DEVICE SX28,TURBO,OPTIONX,STACKX,OSC4MHZ
FREQ 4_000_000
Value VAR BYTE
Temp1 VAR BYTE
Temp2 VAR BYTE
Temp3 VAR BYTE
Result VAR BYTE
PROGRAM START NOSTARTUP
START:
· Value=103
· '·Result=Value * 10 / 64
· Temp1=Value / 8
· Temp2=__REMAINDER * 4
· Temp3=Value / 32
· Temp2=Temp2 + __REMAINDER
· Temp3=Temp3 + Temp2.5
· Result=Temp1 + Temp3
· WATCH Result,8,udec
· BREAK
END
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"One experiment is worth a thousand theories"
Post Edited (Bean (Hitt Consulting)) : 8/9/2005 5:23:32 PM GMT
Bookmark this page: http://www.sxlist.com/techref/scenix/constdivmul_help.htm
It is a web form to generate code to multiply a variable by a constant value (in your case 0.15625). It was designed before the advent of SX/B so the code it spits out is in assembler, but it shouldn't require too much effort to convert (simply code up the ALGORITHM overview in the comments).
For your example it generated the following code (notice it's error is 0%, so this is an exact formula):
·1+1=10
Post Edited (Paul Baker) : 8/9/2005 5:27:41 PM GMT
Cool... Beats the hell out of my code.
Thanks for the link.
Bean.
·1+1=10
"if this is out there imagine what else is out there" - navin johnson
·· You can have the code as in-line assembly with your SX/B projects.· See the ASM/ENDASM commands.
csavage@parallax.com
\ NOP
Jon Williams
·1+1=10
Ken
