Total current capability of the ULN2803 chip
Ok, either I'm not reading the right sheet, or something.. but I can't seem to find what the total maximum current draw is on the ULN2803a. I know it is mentioned that you can sink 500ma per channel, and there are 8 channels, but does this mean I can sink 500ma per channel on ALL channels at the same time?
If so, that would mean I'd be passing FOUR AMPS through that little chip. I imagine the trace size on the PROP-1 may play into this equation as well? Anyway, is there a maximum current draw when all channels are driven at the same time? FWIW, I am trying to set up a PROP-1 to control a 24v motor at up to 1amp of current.
Vern
Post Edited (Vern) : 8/8/2005 11:42:15 PM GMT
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're Senior Systems Engineer | obviously incompetent so why are we Texas Information Services | paying you? Of course,if the network http://www.txis.com | is up, then we obviously don't need Austin Office 512 328-8947 | you, so why are we paying you?" ©VLG
Sid Weaver
Do you have a Stamp Tester yet?
Thats an idea, however, I am planning to use the ParallaxEFX PROP-1 and it already has a socketed ULN2803 on it ready to go... I'd rather use what's there, unless it won't work for this application..?
Vern
·· The ULN2803 is built on to the Prop-1, so you can't substitute it for TIP120's.· Vern, to answer your question the way I am reading the datasheet you can have all channels driving 350mA X 8 at an appropriate duty cycle.· This also means there's no simple answer as it also talks about ambient temp, cooling, etc.
csavage@parallax.com
