How to Measure Ping Signals with Optascope?
Could you please inform me how i can measure the signal off a ping ultrasonic sensor with a optascope( maybe i need a external trigger?)
Thanks by advance
Michel Dechief
Belgium
Post Edited By Moderator (Jon Williams (Parallax)) : 8/7/2005 2:29:03 PM GMT
Thanks by advance
Michel Dechief
Belgium
Here's what I did: I setup a very simple test program like this:
Main:
· LOW 0············ ' initialiaze Ping trigger pin
· PULSOUT 0, 250··· ' long trigger pulse
· INPUT 0·········· ' allow echo to be seen
· END
Since PULSOUT inverts the pin state we need to start with the pin low.· Then we do a wider-than-normal trigger·PULSOUT so that it can be seen on the scope.· In normal applications the next line would be PULSIN which makes the pin an input -- for this test we'll just simplify with the INPUT instruction so that we can see the echo pulse (if we didn't do this, the Stamp would hold the pin low and we wouldn't see the echo).
Setup your scope to trigger at 2 volts or so, rising edge, single acquisition.· When the scope is armed (click Run/Stop) you can reset your Stamp circuit and you should capture two pulses like in the image I've attached.· In my case the echo pulse is 8720 uS wide.· Remember that this is the time for the pulse to go to and return from the target (ceiling in my case), so we have to divide this value by two.
8720 / 2 = 4360······················ -- actual distance in uS
4360 / 73.746 = 59.1 inches
4360 / 29.034 = 150 cm
PS: Don't forget to add a subject line to your new posts -- I fixed this one for you.
Jon Williams
It working without problem.
But i stay with problem when i would to test voltage above 20 volts(i'm working in to earth moving material and voltage are 24 volt + charging of alternator.
How can i do a voltage divider or a normal transfo to take my measerements.
Thanks by advances
Michel Dechief
Belgium
