RF Keyfob Transmitter/Reciever Information
Board,
I purchased a pair of transmitter/reciever's for a different application, however after having recieved them, I'm likly to purchase more for a different purpose.
I was disappointed in the lack of any information on the units..... anywhere. Apparantly, Parallax obtains these units from rfdigital.com as the PCB for the reciever has rfdigital.com on it. However, Linx makes the keyfob, and the IC for the reciever that rfdigital.com has.
I found out the following primary points.
1) These units can be used for a "secure" type item. The product is designed for use in alarm systems and things of this nature. So long as you change the address.
2) Multiple transmitters (keyfobs) can be used with one reciever.
3) The data is encoded. And hack resistant. I say hack resistant because nothing is hack proof. Ask DirecTV.
4) You can change the address's of the units, so that you can use multiple transmitters/recievers that are independant of each other, if you want. (IE, My parents live next door, so I can have one and they can have one and no interference.)
5) Unfortunate part. There is 1024 different possibilities. This is almost small enough to have someone determined to sit there are attempt to find the correct code. Unlikly, but I'd be happier if it had one or two more bits.
I'd really appreciate it if this info was on the webpage. I've included a jpg set of the manual's of the keyfob. I have cut the traces as described in this manual on both the reciever and transmitter and successfully changed the address of my system.
Just wanted people to have access to this information. [noparse]:)[/noparse]
www.parallax.com/detail.asp?product_id=28004
www.parallax.com/detail.asp?product_id=28005
www.linxtechnologies.com
Knight.
Post Edited (knightofoldcode) : 8/6/2005 8:51:19 AM GMT
Knight.
·1+1=10
Post Edited (Paul Baker) : 8/6/2005 1:54:40 PM GMT
I agree completly. And I know that it's not a code hopping system. [noparse]:([/noparse]
However I can't find anything that does this. At the moment I'm just using it to turn on and off my air compressor's solenoid, for a upcoming halloween project, and was considering using it for my home alarm system, but I think the security is just too low to use it for that application, after having considered it over the last day.
However, it does still give the option of preventing multiple transmitters/recievers from interfering with others. [noparse]:)[/noparse]
Do you, or anyone else know of a code hopping system for BS users?
Knight.
·1+1=10
Cool, cool. [noparse]:)[/noparse]
If you can't, it's not a big loss. I think RFID is the way to go. [noparse]:)[/noparse] I just wish it was a little longer range.... [noparse]:([/noparse] That way I could keep it in my pocket.
As it stands, when you want to open the door, it'll be something like the old Monty Python skit.... "I wave my private parts in your general direction!".....
I assume, in your opinion that the RFID module (the reader and transmitter's sold by Parallax) is secure for house security?
TIA,
Knight.
Microchip manufactures a product line they call KEELOQ which might be what you are after. They have a variety of code-hopping encoders/decoders/transcoders that are available as single chip solutions. While they are not designed specifically for use with the STAMP, I am sure they are designed to function with Microchip PIC controllers, which are at the heart of several of the Parallax STAMP products. Check out the security products section of their website at:
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=77
peter
Peter C. Charles
Director, Research and Technology
CyberBiota, Incorporated
Peter.charles@cyberbiota.com
http://www.cyberbiota.com
