Help on Sound Module AppMod
I have decided to use the Sound Module to my next robotics project.
Today the module is on my hands and I can see the programming documentation is very short, so I am plenty of questions and no answers at all...
Actually· I don't know how to get the value of the internal pointer of Module in order to address the playing of specific message from my BasicStamp. Also I don't know how to get the pointer value in order to record a message next to the messages recorded earlier, without erase the whole memory to record new message, using the SEROUT commands to control the Module.
I really need some help on this, I mean if you sugest some code, examples and advices will be very useful for me at this point. Of course I have read carefully the soundmodule.pdf in Parallax site
Thanks in advance, best regards
merlin
merlin
If you use serial out in this manner you can explore what to write
SEROUT pin,baud,[noparse][[/noparse]comand or address]
Make a list of commands to start and then try them out but BE SURE NOT TO SEND A RECORD COMMAND UNLESS you want to PROGRAM AN ENTIRE SOUND/VOICE LAYOUT.
TRY SENDING A VOLUME LEVEL THEN A PLAY COMMAND THEN THE ADDRESS TO BE PLAYED.
Thanks for your time and explanation.
I can understand (even I don't like it...) the need to record the whole voice layout in one shot. What I trying to do, when all the messages are recorded, and of course each one with differents durations, is to locate via pointer the address of some particular messsage.
I know how to do this adding in the Play Serial Command the correct address parameter , what I don't now is HOW to get the correct value of that pointer for some particular message.
In last page of the text attached with the module, there are a time location table, but I can't understand the variables they are using to setup this table, referred to the example included in the text.
In other words, my question is: how to get the memory address for each message recorded earlier.
Thanks in advance for any help on this
merlin
The module uses the ISD2560 which can record up to 60 seconds and has 600 cells; this makes each cell 0.1 seconds. You can, then, estimate an address based on where the segment is time-wise. After initially estimating you should be close and can fine-tune your starting address from there. It would be very useful for you to create a simple demo that allows you to enter the address from the DEBUG window -- you can do that with DEBUGIN. Remember to use a Word for your address value.
Jon Williams
