QT60000 Series Touch sensor
Does anyone have any experience with the QT60168/QT60248 or any other QT60xxx?· I’m thinking about using one in an upcoming project. Just wondering if anyone had nightmares or success stories, they care to share.·
Datasheet
http://www.qprox.com/downloads/datasheets/qt60248_402.pdf
Datasheet
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
12 * 8pin dip = 96 holes to drill!! ahhhhhhhh!· Where's the pcb drilling machine?
Post Edited (Orion) : 8/10/2005 11:26:01 PM GMT
I'm a newbie on this site.
Did you ever get any further with the QT matrix chips(QT60168/60248)?
I have a working project with the 16 key version, but am having a permanent error code. Although the unit deilvers the correct code for keys in use, it also tell me that it is permanently calibrating! Wierd or what! (The reponse to command 0x06 always has bit 6 high which is an error code. This will mean nothing unless you have used the chip! There is no comms error, FMEA error or anything except permanent calibration.)
If anyone has any ideas please get in touch.
