BS2 working in robotic without its MainBoard — Parallax Forums
SRLASRLA Posts: 19
edited 2005-08-14 06:36 in Robotics
Some people said to me that if i already have a robot design, could I use the BS2 with its conections alone, without the MainBoard?, that's truth?, Thanks.
  • Tricky NekroTricky Nekro Posts: 218
    edited 2005-08-06 10:30
    if you know what every pin is for you can...
    But they were not using a BS2 module,· but the PIC itself...with the parallax compiler and,·of course,·factioning with PC and PBasic...
    -Rule your Destiny-
    --Be Good. Be Bad. Be Provas--
  • SRLASRLA Posts: 19
    edited 2005-08-13 00:32
    Thanks, in that case, How I can connect the BS2 with power supply?, I guess with Vdd and Vss, is it truth?
  • dandreaedandreae Posts: 1,375
    edited 2005-08-13 03:13
    You can use the Vin to Vss with 6v to 12v or Vdd to Vss with 5v.
    Dave
    Dave Andreae
    Tech Support
    dandreae@parallax.com
    Http://www.parallax.com
    OK, thanks, then I can use it just in connections with the other devices and the power source without using the board. It's to reduce size.
