Looking for some ideas for snow and rain sensor
Glad to have this forum. There are many talented individuals here and when I ever have a problem I know where to go.....!!
Here is the problem. I have a remote outdoor camera at a remote location. It has a windshield wiper assembly and I want to control the motor when it snows or rains. The location gets about 7 feet of snow in the winter and the average temperature is below freezing. The camera housing does have a heater, but I know that if it snows it will eventually freeze on the glass, and it would be impossible to thaw or move with the wiper. I have thought about a photocell-light detector, but I think the snow would eventually make it usless as well.
Any ideas would be greatly appreciated.
Thank You
Guido
Thank You
Guido
I have another thought as well... an IR beam (perhaps even a laser) that goes across the front of the window so that anything on the glass will cause the beam to be broken.
I hope one of those at least sparks a thought that will help you.
So what is the (photocell) detector for? Is it to prevent the (frozen) wiper from moving? Or to confirm the wiping has occurred? Or that it's been snowing and to take a picture?
I don't understand your problem.
Cheers,
Peter (pjv)
Well, I would add a hood to keep rain/snow from hitting glass, as this would reduce a lot of the problem.
Bob N9LVU
·1+1=10
www.parallax.com/detail.asp?product_id=604-00038
kelvin
Kevin, I think you have a great idea, I am going to have to give it a try when they come back in stock. This way everything stays in side the camera housing for protection..Thank You All again!
Guido
[url=http:// http://www.qprox.com/toolbox/index.php?submitted=1&partNo=QT113-D] http://www.qprox.com/toolbox/index.php?submitted=1&partNo=QT113-D[/url]
kelvin
When the temp gets to 38 degrees fahrenheit, the heater element comes on, then any snow that falls on the sensor (think of a small funnel here) melts and runs onto the moisture sensor. The moisture sensor then give me a signal that I can reliably interpret as being from snow. Since it is only active when the temp is below 38. Pretty simple and reliable, lasts for years. Google snow melting systems for more details.
Danny
"Never create anything you can't control"
"The amount of intelligence on the planet is fixed... the population is growing"
When contaminants cover the glass, more light will be reflected back in to the enclosure...this is where you could have a photocell of some sort picking it up.
We use this method on some of our laser ceilometers. Birds like to hang their rear-ends over the lens and black our measuring beam.
As far as determining snow from rain...just use a temp sensor....there's the obvious gray zone from -5degC to +5degC of whether it's snow/rain/frozen precip.
You could also use a contact sensor...basically it looks like a bare circuit board with traces going back and forth. When precip hits this board it shorts out and gives a resistance OTHER than Infinite (open)....and you could heat this board for snow too (just use a little 5W resistor underneath with some power going thru it--that's all those Pelco camera boxes do).
IF you want to get real fancy....purchase a surplus police radar gun. Aim it up and measure the speed of falling precip. This, along with a temp sensor, will let you determine the type of precip falling (snow falls slower than rain...but false calls are made with frozen rain and hail and such). This is a fun way to do it...but certainly overkill.
Steve
