Communication problem between javacs and Basic Stamp(sx) via RS232
I am trying to send commands from a java program (using javacs.comm, java extension communications) to my BSsx. The bauds are off course set to the same on both side. 8-bits, no parity, 9600 b-rate and so on. I have also tried on slower baud rates..
The BSsx is programmed only to listen to the SERIN and GOSUB (drive a stepper motor via Little Step U), when receiving any data (one byte).
The java-program is programmed to locate the COM1, open it, and send one byte data, hold the port open five seconds, and then close the port.
The BSsx program work fine when using a terminal–program (RealTerm), but not with the java-program, and the java program work fine separate to.
Why is my system not working?
Please see attached files, TestMain.java , SerialIO.java (java-files) and TestMain.bsx (basic stamp-file).
Please, if anyone have done anything like this, please give me some advise! If anyone have any type of suggestion on haw to move on, don’t hesitate to reply this.
Regards//jw
Regards//jw
Jon Williams
I don't know if Java gives you the option of opening the port without letting the DTR line transition.
