BIOS Reader\Writter
I have heard on several occasions that all the bios flashing can ruin a motherboard. For this reason I was wondering if it was possible to use the basic stamp to read off the contents of the BIOS for a backup to be restored if·the BIOS gets ruined by the bios fashing utillity.··
·· Reading the chip isn't the problem so much as getting the data back into the computer as a useable file.· But that's really beside the point, since every BIOS flashing utility I have seen has a function to save the current BIOS as a file.· Most manuafcturers recommend that, as well as not flashing your BIOS just for the sake of having the latest verison, but only if you're experiencing an issue related to the update.
csavage@parallax.com
However, it IS nice to have a backup file of your BIOS eeprom, just in case the original eeprom gets 'stepped on' inadvertently.
·· Now whether it gets flashed too many times or stepped on, it doesn't really matter.· You either have a backup, or you don't.· Many companies such as ASUS have a standard fee, such as $5.00 to send in your failed BIOS chip and have it re-flashed by them with the latest BIOS version.
The voltage needed to program the chips and the timing varies wildly from type to type, and doing it the wrong way may let out the magic, blue smoke.
Of course, then you'd also need a program that can either convert the saved BIOS image to a format the burner understands, or a program that can 'rip' the BIOS image directly from the PC.
Don't visit my new website...
There are commercial solutions to just this problem. For instance, my motherboard has "C.P.R." Basically it's got two BIOS's, if the first one failes, it switches to the second one, the second one can't be wrote to, it's the "defaults". Then using that second bios you can reflash your first running bios. My Motherboard is a Asus P4PE, REALLY good board.
However for your situation, in that your trying to implement this in a computer lab, I have to assume that you'll rarely encounter this.
They do still offer a commercial version. Look at these links:
http://www.frozencpu.com/bio-01.html
http://www.frozencpu.com/bio-02.html
http://www.frozencpu.com/bio-03.html
http://www.frozencpu.com/bio-04.html
If these links don't work, go to fronzencpu.com and under search, enter "Bios Savior".
This solution is designed for use in a permanent setting. However, I have the full compliment of 4, for my computer shop (they are only hooked into a customer's machine until the flash is completed, and verified working.) These work excellent, and I have used Frozen CPU in the past, and had nothing but good business with them.
The only problem with this solution is that it can't be backed up into a file and saved on a CD. And, you're not able to repair a system that has already been screwed up by the customer, this only saves you if the computer shop or you, screw it up. I have had customers who flashed, "because a friend said I should", and power goes out. All my systems are battery, and propane backed up when I do a flash for a customer.
Knight.
