LCD 16x2 Need help...
I have a 16x2 LCD with backlight - LCD Duty = 1/16 & LCD BIAS 1/5 and a SPLC780D Driver w/ TC1602A-01 & TC1602A-08
Need help to hook to the BS2 module and source code to get to work, I just want to customize the disply to say hello, testing, etc...
pin 1 = Vss
pin 2 = Vdd
pin 3 = V0
pin 4 = RS
pin 5 = R/W
pin 6 = E
pin 7 = DB0
pin 8 = DB1
pin 9 = DB2
pin 10 = DB3
pin 11 = DB4
pin 12 = DB5
pin 13 = DB6
pin 14 = DB7
pin 15 = A (Back Light)
pin 16 = K (Back Light)
Gus
pin 1 = Vss
pin 2 = Vdd
pin 3 = V0
pin 4 = RS
pin 5 = R/W
pin 6 = E
pin 7 = DB0
pin 8 = DB1
pin 9 = DB2
pin 10 = DB3
pin 11 = DB4
pin 12 = DB5
pin 13 = DB6
pin 14 = DB7
Gus
·· Please refer to our connection information on the following web page:
http://www.parallax.com/detail.asp?product_id=603-00006
That page has the necessary code and wiring diagram to get you going.· Specifically, you'll want the manual (PDF) and the source code (ZIP).· The connections from the LCD to the Stamp I/O pins will be what you want.· Use the 4.7K resistor on the E line (P0) the other resistors are not necessary on most LCD Displays.
csavage@parallax.com
Post Edited (Chris Savage (Parallax)) : 8/1/2005 8:45:11 PM GMT
http://www.parallax.com/dl/docs/books/sw/exp/sw11.pdf
Jon Williams
Bruce Bates
