Counting without time limit and comparing to variable
Hello
I want to count a hall effect sensor with my BS2sx but not within a time limit. I want to be counting all the time until i reach the value of·a variable(word size). I was thinking of the lookdown command and adding 1 to·another variable each time·the sensor reads a magnetic fiels,·until my lookdown command sees tey are the same.
Does anyone have a suggestion, correction, tip?
Everything you write is warmly welcome.
Thanks for all the help i may recieve.
Best Regards
Manuel C. Reinhard
Best Regards
Manuel C. Reinhard
·· You might try something like:
' {$STAMP BS2p} ' {$PBASIC 2.5} Target CON 1234 Current VAR Word DO IF IN0 = 1 THEN Current = Current + 1 DO : LOOP WHILE IN0 = 1 LOOP WHILE Current < Target▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
csavage@parallax.com
Best Regards
Manuel C. Reinhard
·· Whoops!· Yes, it does...I had a BS2p in the board already when I tested the code, but as long as you have the PBASIC 2.5 syntax selected, you're fine.· You just need to change the Stamp directive to BS2sx.
Best Regards
Manuel C. Reinhard
Best Regards
Manuel C. Reinhard
·· On the SX, it's possible, although I haven't checked the timing.· You could try it though.· Timing for the BS2, and I think the BS2sx can be found on Dr. Tacy Allen's website at www.emesystems.com·along with a wealth of other useful information!·
Best Regards
Manuel C. Reinhard
·· That is correct.· The DO...LOOP exits when the Target variable has been reached.
