BS2SX and servo controller
Please Help I just purchased a servo controller but it don't want to work. I have tried To identify firmware version number and set the baudrate. I have a steady red led and a blinking green led on the servo controller also the servo is locked I assume in mid range I am using #15 pin for serout. what am I doing wrong??· Hank
·· Since you are using a BS2sx, have you set the baud rate parameters correct for a BS2sx?· The ones in the demo code are for the BS2, which is different.· The help files can tell you the correct baud rate parameters for your Stamp Module.
csavage@parallax.com
#SELECT $STAMP
· #CASE BS2, BS2E, BS2PE
··· T1200······ CON···· 813
··· T2400······ CON···· 396
··· T4800······ CON···· 188
··· T9600······ CON···· 84
··· T19K2······ CON···· 32
··· TMidi······ CON···· 12
··· T38K4······ CON···· 6
· #CASE BS2SX, BS2P
··· T1200······ CON···· 2063
··· T2400······ CON···· 1021
··· T4800······ CON···· 500
··· T9600······ CON···· 240
··· T19K2······ CON···· 110
··· TMidi······ CON···· 60
··· T38K4······ CON···· 45
· #CASE BS2PX
··· T1200······ CON···· 3313
··· T2400······ CON···· 1646
··· T4800······ CON···· 813
··· T9600······ CON···· 396
··· T19K2······ CON···· 188
··· TMidi······ CON···· 108
··· T38K4······ CON···· 84
#ENDSELECT
SevenBit······· CON···· $2000
Inverted······· CON···· $4000
Open··········· CON···· $8000
Baud··········· CON···· T9600
Jon Williams
BaudSlow······· CON···· T2400 + Open
BaudFast······· CON···· T38K4 + Open
Jon Williams
