Sample code for "418 Mhz Receiver-Keychain"
I'm looking for a sample code to use the keychain and the receiver (with a bs2) . Is there someone who kindly helps me ?
Thanks a lot !
Viktor18
Thanks a lot !
Viktor18
btnStatus··· VAR··· Byte
Main:
· btnStatus = INL & %00011111
· DEBUG BIN5 btnStatus, CR
· PAUSE 100
· GOTO Main
Jon Williams
So , thanks again !
As it is, the received high signal is only one of four, One goes high and three go low.·
If you want to retain previous high signals rather than reset, you have to do that in your software as toggles·or insert a 74HC112 as four independent toggles.· Either way, they would toggle on the high signal.
G. Herzog in Taiwan
I have some more examples at work, send me an e-mail at dandreae@parallax.com and I will send you some sample programs.
Dave
Dave Andreae
Tech Support
Http://www.parallax.com
