barcode
hey,
i was thinking it woul;d be cool to prgm a bot with barcodes and a barcode reader has anyone done this or does anyone have any advice?
-MM
-MM
·1+1=10
Using a commercial·barcode scanner would depend upon the model, clearly youd want either a parallel or serial interface and not·USB.
·1+1=10
zebra may still make a pen type barcode universal scanner that hooks up to a rs-232 port. My recolection is that after programming to a specific mode it stays set up on that particular code. I use mine on upc code. The original wand is made by hewlet packard......
73
spence
k4kep
-MM
I followed the conversation about·the barcode reader.
Some time ago, i picked up a Datalogic DLC7070-M1 from Ebay. It cost me about 20 or 30 Euros and it can be configured to work between a pc's keyboard, like a pen reader, or just act like a normal RS232 device.
It works up to a distance of about 20cm's (8 inches?) and it's just aim and shoot, with a trigger.
I'm sure that such a device can be altered to fit into the described situations.
Good luck with the project!
Ed.
