curious "View Active Threads" action
Jim,
When I clicked on the View Active Threads link at the bottom of any message·thread, the URL resolves to page http://forums.parallax.com/forums/atopics.aspx, but the content that is eventually (after about 10-15·seconds) served suggests that there is a script problem.· That content served is:
Daniel
View Active Threads said...
Server Error in '/' Application.
Runtime Error
[font=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif ]Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.[/font]
Daniel
Thanks for posting the error and the surrounding details. I will check this against the system logs, but I'm pretty sure that this happened during a server update. Microsoft is going nuts with patches again.
Jim
Parallax IT Dept.
For what it worth, I clicked ViewActiveThreads just now and got the same error message. Are you still patching?
Daniel
