stepper motor suggestions
I have·some questions about using the Mitsumi·12V 4 phase Unipolar stepper motor.· First, I was planning on using the BASICstamp as the indexer and·two ULN2803 transitor drivers to run two stepper motors simultaniously.· However, after reading·the·literature·I want to make sure·I·will get the performance I need.· I need to have a lot of torque (around 8 kg-cm)·under varying loads to move a paddle through a pile of sand.· Does anyone have any suggestions or recommendations on this setup?· By the way, I can not use R/C servos because I need position control for a full 360+ degrees, unless you know an easy solution.· Thanks for the help and take care.
·1+1=10
how precise your run must be ?
Are you making a suggestion or are you asking about how to use an encoder with a servo?· We do offer encoders that can be used with servos.· Here is a link for more information:·http://www.parallax.com/detail.asp?product_id=28107·.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
