Help File Freezes !
every time i open my help file the help file 100% freezes cannot do a thing with the help file.
when i hit the small "x" to close it states "Programm not responding"
What is Going on...
I have a High quality Gaming Computer and i am pretty sure that it can handle a little help file.
Computer specs.
AMD XP 3200 (2.2Ghz)
Windows XP Pro
1 GB DDR2 (memory)
120 SATA HDD
I just dont know whats going on
I even tried installing the latest version to Pbasic v2.2 and still i get a freeze.
Help Please....
There are 10 kinds of people....
Those who know binary and those who Don't.
What is Going on...
Computer specs.
Windows XP Pro
1 GB DDR2 (memory)
120 SATA HDD
Help Please....
Have you checked the windows update page?
Best Regards
Manuel C. Reinhard
If it opens other help files then go to Parallax and download a new help file and try to open that one.
If that woks then replace you existing help file with that one.
- - - PLJack - - -
Perfection in design is not achieved when there is nothing left to add.
It is achieved when there is nothing left to take away.
If you scroll down with the cursor keys it would be allright...
It happens on every PC I tried so its not hardware related... It·think that parallax have a fix for this on the software downloads.
Whatever problem you're having is not hardware related, but it is not related to the file itself which is constructed using the Microsoft Help Compiler -- I'm guessing the problem has to do with the version of Internet Explorer and related components you have installed on your machine.
Jon Williams
The freeze occured to me in an older version 2.1 beta version I had...
·· The main question I have, is can you run the help from the Start Menu icon instead of from within the editor?
csavage@parallax.com
Jon, I dont even get the option of using the PgUp PgDn keys.. when its opened its frozen !
i just dont understand. i have pbasic installed at my work computer and i have never had a problem with it.
i never knew you could open the help file without pbasic running so i will give that a try.
Thanks to all the response.
Jon Williams
