Interface with 3.3v devices — Parallax Forums
RShirleyRShirley Posts: 12
edited 2005-07-27 18:08 in General Discussion
Hi all,
I am tring to talk· to a Trimble GPS module which is 3.3v. Its comm lines are CMOS compatible. I think·the GPS tx·to Javelin rx·would work.·I don't think it would be safe to connect straight·from the Javelin tx to the GPS rx, 5v driving 3.3v.·Any ideas?
Thanks, Russell
    You are correct that you can feed a 3.3V signal into the javalin and be able to properly read the value under all but the noisiest of conditions. To step the Javalin's 5V down to 3.3V you should use a voltage divider, typically the values of 1.8 kΩ and 3.3 kΩ are used. http://www.captain.at/electronics/pic-mmc/·shows a schematic for connecting a 5V microcontroller with a 3.3V device (a MMC in this case), note the voltage dividers for the /CS, DATA IN and CLK lines (all inputs for the MMC).
    ·1+1=10
