BS sx + stepper motor + PCF8574
hi all,
I've working on hooking up with 2 stepper motors (+ULN2803) + PCF8574, below is the code that I wrote for 1 stepper (P0-P3). I would like to add 1 more stepper to P4-P7 (of the same PCF8574).
I don't quite understand the shifting of bits and how it works in PCF8574, please help for changing the code to drive 2 stepper or show me pointers.
code:
' I/O Definitions
SDA CON 8 ' I2C serial data line
SCL CON 9 ' I2C serial clock line
' Constants
DevType CON %0100 << 4 ' device type
DevAddr CON %000 << 1 ' address = %000 -> %111
Wr8574 CON DevType | DevAddr | 0 ' write to PCF8574
Rd8574 CON DevType | DevAddr | 1 ' read from PCF8574
ACK CON 0 ' acknowledge bit
NAK CON 1 ' no ack bit
MixDDR CON %11110000 ' 1 = input for mixed I/O
Yes CON 0
No CON 1
CrsrXY CON 2 ' DEBUG Position Control
' Variables
i2cSDA VAR NIB ' I2C serial data pin
i2cData VAR BYTE ' data to/from I2C device
i2cWork VAR BYTE ' work byte for I2C TX code
i2cAck VAR BIT ' ACK bit from device
counter VAR NIB
i VAR NIB
delay VAR BYTE
delay = 40 'slow the step speed
' EEPROM Data
' Initialization
Initialize:
PAUSE 250 ' let DEBUG open
DEBUG CLS, "PCF8574 Demo"
i2cSDA = SDA ' define SDA pin
i2cData = %11111111 ' clear outputs
GOSUB Write_PCF8574
IF (i2cAck = ACK) THEN Main ' device is present
DEBUG CLS, "Error: No ACK from PCF8574"
END
' Program Code
Main:
FOR i = 1 TO 10
GOSUB Main1
PAUSE delay
GOSUB Main2
PAUSE delay
GOSUB Main3
PAUSE delay
GOSUB Main4
PAUSE delay
NEXT
GOTO Main
Main1:
DEBUG CrsrXY, 10, 2, BIN4 i2cData ' display counter on screen
i2cData = %0101 'I/O pins 0 and 2 high
GOSUB Write_PCF8574 ' display counter on LEDs
RETURN
Main2:
i2cData = %1001 'I/O pins 0 and 2 high
RETURN
Main3:
i2cData = %1010 'I/O pins 0 and 2 high
RETURN
Main4:
i2cData = %0110 'I/O pins 0 and 2 high
RETURN
' Subroutines
' Data to be sent is passed in i2cData
Write_PCF8574:
GOSUB I2C_Start ' send Start
i2cWork = Wr8574 ' send address
GOSUB I2C_TX_Byte
i2cWork = i2cData
GOSUB I2C_TX_Byte ' send i2cData to device
GOSUB I2C_TX_Byte ' force to pins
GOSUB I2C_Stop ' send Stop
RETURN
' Data received is returned in i2cData
' Low Level I2C Subroutines
' --- Start ---
I2C_Start: ' I2C start bit sequence
INPUT i2cSDA
INPUT SCL
LOW i2cSDA ' SDA -> low while SCL high
Clock_Hold:
IF (INS.LOWBIT(SCL) = 0) THEN Clock_Hold ' device ready?
RETURN
' --- Transmit ---
I2C_TX_Byte:
SHIFTOUT i2cSDA,SCL,MSBFIRST,[noparse][[/noparse]i2cWork] ' send byte to device
SHIFTIN i2cSDA,SCL,MSBPRE,[noparse][[/noparse]i2cAck\1] ' get acknowledge bit
RETURN
' --- Stop ---
I2C_Stop: ' I2C stop bit sequence
LOW i2cSDA
INPUT SCL
INPUT i2cSDA ' SDA --> high while SCL high
RETURN
Cheers,
code:
' I/O Definitions
' Constants
Yes CON 0
No CON 1
' Variables
counter VAR NIB
i VAR NIB
delay VAR BYTE
' EEPROM Data
' Initialization
Initialize:
GOSUB Write_PCF8574
END
' Program Code
Main:
FOR i = 1 TO 10
GOSUB Main1
PAUSE delay
GOSUB Main2
PAUSE delay
GOSUB Main3
PAUSE delay
GOSUB Main4
PAUSE delay
NEXT
GOTO Main
Main1:
RETURN
Main2:
RETURN
Main3:
RETURN
Main4:
RETURN
' Subroutines
Write_PCF8574:
GOSUB I2C_TX_Byte
i2cWork = i2cData
RETURN
' --- Start ---
INPUT i2cSDA
INPUT SCL
Clock_Hold:
RETURN
' --- Transmit ---
I2C_TX_Byte:
RETURN
' --- Stop ---
LOW i2cSDA
INPUT SCL
RETURN
Cheers,
· i2cData = motor2 << 4 + motor1
That will align the outputs correctly and allow you to update the coils on one motor without changing the other.
Jon Williams
