SX_key Dilemma's
Hi All,
I have just recently purchased another SX-key and I seem to be having some problems with the unit.
I am trying to program code into an SX 52 with the new key and am not having much luck,
the circuit has the correct voltages and I have been able to use the old key to program the device successfully.
When I try and program the device with the new key I am getting different errors thrown by the SXkey Version 3.1 IDE
for example
Communication Error : 164
Communication Error : 66
Communication Error : 162
Communication Error : 223
Communication Error : 159
etc
I am not to sure what is going on. Possibly a broken SX_key! Any ideas that would shed some light on this problem would be greatly appreciated.
Thanks in advance
Stolzie
for example
etc
Thanks in advance
Stolzie
·· So, does your old key work?· Just out of curiosity, why did you get a new key?
csavage@parallax.com
Yes my old key works fine does everything it is suppose to do!
I needed another key so that I was able to program chips twice as fast!
It is a lot quicker to get product out the door when you have two people programming units.
Stolzie
·· Well, if plugging the old one in works fine, and simply replacing it on the same machine the new one doesn't work, then perhaps there is a problem, and you should contact Tech Support for an RMA.
-Dan
Code...
Call······ @FindProblem
Loop1··· Jmp· Loop2
Loop2··· Jmp· Loop1
Call······ @ProblemSolved
·· He's already in the forums...
-Dan
Will get in contact with the distributor that I bought the key off and get a replacement.
Thanks again
Stolzie
