Using the ADXL202 instead of the Memsic 2125 Dual-axis Accelerometer
I would like to have a schematic drawing showing how to connect the ADXL202 to the BS2, and some sample code.
The "BASIC Stamps Archive" contains several threads about using the ADXL202, and even indicated that Parallax sold the part at one time. If anyone has copies of the circuits and the code that was developed at that time I would appreciate getting a copies of it.
About four years ago we sold the ADXL202EB evaluation kit. Our package of web downloads is attached. I used this part on my R/C airplane as an in-flight level controller.
Tanner Electronics received a small quantity of the parts in 14-Lead CERPAK (not the evaluation board). They will need to be mounted on a surface mount adapter board to be used in the way that the MEMSIC parts are used.
Given the attachments that you provided and the information on the evaluation board from:
http://www.analog.com/UploadedFiles/Evaluation_Boards/Tools/246132389ADXL202EB_a.pdf
it will be possible to use the IC with the BS2.
Russ
I noticed a difference between the formulas that each spec gives for acceleration.
MEMSIC Spec sheet for MXD2125 Rev D page 5 Figure 3
A(g) = (T1/T2 - 0.5) / 20%
Analog Devices Spec sheet for ADXL202 Rev B page 6 Figure 12
A(g) = (T1/T2 - 0.5) / 12.5%
The Parallax documentation uses the formula from the Analog Devices Spec sheet
"Memsic 2125 Accelerometer Demo Kit (#28017)"
page 2 Figure 2
Is this a typo on the MEMSIC spec sheet?
The value of 12.5% is correct (per message from Andy):
Either the datasheet is incorrect or it covers multiple chips. The pulses that come from the thing have about a 10 ms cycle time, and when they are horizontal, the duty cycle of the pulses is 50%. Taking one axis from vertical to horizontal, to vertical the other way results in a variation of +/- 12% in the duty cycle. At room temperature, this tilt sequence will give you high times that go from 3.75 to 5 to 6.25 ms (assuming exactly 10 ms cycle time). The duty cycle varies sinusoidally with tilt, so inverse trig will give the correct angle. Tracy Allen (www.emesystems.com) published a technique for doing that with the BASIC Stamp, and Jon Williams incorporated it into the example code in our datasheet.
Hope this helps.
Ryan
Ryan Clarke
rclarke@parallax.com
Thank you for looking into this and posting this response.
