LCD — Parallax Forums
LCD
theyetheye Posts: 31
edited 2005-07-27 03:33 in Robotics
hey can i put a LCD from a cd player in my boe-bot?
    edited 2005-07-26 04:29
    ·· Most likely you can't, unless it happens to be Hitachi compatible, which usually aren't found in these types of devices.· Most likely the LCD you refer to requires a controller.
    csavage@parallax.com
  • theyetheye Posts: 31
    edited 2005-07-26 17:45
    where i can found a hitachi compatible?
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2005-07-26 19:04
    theye -
    In the outline below items with an asterisk (*) indicate the most standard options.
    1. Where are you located geographically (country)?
    2. What is your price range?
    3. What format are you looking for:
    a. number of lines -
    1) one, (*)
    2) two or (*)
    3) four?
    b. approximate or actual line width:
    1) 4-15 characters
    2) 16-19 characters (*)
    3) 20-24 characters (*)
    4) 25-40 characters (*)
    4. Backlighting for improved visibility in dark situations?
    a. If so, which type of backlighting -
    1) LED (*)
    2) ELP - electroluminescent
    3) CCFL - cold cathode fluorescent
    4) woven fiber - integrated optical fiber
    5) incandescent
    b. Which backlighting color, if available?
    1) green (*)
    2) yellow
    3) blue (*)
    4) red
    5) orange
    6) white
    5. Is cold weather an issue?
    6. Approximate size, if size is an issue.
    The answers to those, and possibly a few more questions will zero in on an applicable LCD unit that should meet your needs, and is affordable.
    Bruce Bates
  • ForrestForrest Posts: 1,341
    edited 2005-07-26 19:11
    The least expensive LCD's that can easily be connected to a Basic Stamp is a Hitachi HD44780 compatable display. Use Google to search for them. These displays are available from many surplus electronics suppliers for around $5 for a 2 x 16 display. The HD44780 is a parallel interface and requires at least 7 pins to interface with a Basic Stamp. If you want an LCD that only requires 1 pin to interface - check out www.parallax.com/detail.asp?product_id=27976
  • Tom-Matrix OrbitalTom-Matrix Orbital Posts: 38
    edited 2005-07-26 20:31
    Have you also thought about Matrix Orbital displays?
    http://www.matrixorbital.com/
    i am from puerto rico and really i start with my boe-bot about 1 month and don't really know how pins and how many characters i need. I just only want a recomendation of where i can find one in my house or in a store that cost about 20 dollars. The thing is that i don't want to buy it from internet.
