BS2 And Dallas One Wire, Can it be done?
I havn't even really had a chance to look, but I was wondering if anyone had any success at creating a method of putting a dallas one wire IC onto a BS2's pin.
I'm mostly trying to get a DS2401 onto a BS2.
The DS2401 is a silicon serial number, I want to have multiple stamps, and need a form of identification for these stamps, this would take up significantly less number of pins than a "dip" switch style ID system.
Jon Williams
THEN YOU CAN CHANGE SERIAL NUMBERS AS YOU WANT.
73
SPENCE
K4KEP
Post Edited (SPENCE) : 7/23/2005 12:10:13 PM GMT
Thank you, Jon, I was afraid I'd have to implement a One-Wire-To-Serial converter, but wasn't sure if it could be done with the BS2, without a converter. Would the converter you spoke of be a DS2480B?
I am very likly to just go with a set if dip switches and a parallel shift register, after looking at the data sheet for the DS2480B.
Knight.
Jon Williams
This is for a product that might (one day, maybe) get sold to the public. I don't want the public to have to reprogram the EEProm. [noparse]:)[/noparse]
Nevermind, I catch what your saying. Instead of programming into the EEProm the device code for that house, you'd program in a unique serial number into the EEProm. That's an option, however it's not as.... streamline? as I'd like. I think I'm just going to go with a set of 8 dip switches. I appreciate the suggestion though, I hadn't thought of it. [noparse]:)[/noparse]
