Write to eeprom above address 255 and read it back
' {$STAMP BS2}
' {$PBASIC 2.5}
READING VAR Word
VAL VAR Word
EE_PTR VAR Word
EE_PTR = $000
READING = 0
FOR EE_PTR=0 TO $12C' write some readings to EEPROM
READING = READING+5
WRITE EE_PTR, READING
NEXT
FOR EE_PTR=0 TO $12C ' now dump the results to the PC
READ EE_PTR, VAL
DEBUG DEC4 VAL , " "
IF ((EE_PTR = 0) | ((EE_PTR+1) // 10 <>0)) THEN SKIP_CR
' else
DEBUG CR
SKIP_CR:
NEXT
END
AND THE OUTPUT IS
0005 0010 0015 0020 0025 0030 0035 0040 0045 0050
0055 0060 0065 0070 0075 0080 0085 0090 0095 0100
0105 0110 0115 0120 0125 0130 0135 0140 0145 0150
0155 0160 0165 0170 0175 0180 0185 0190 0195 0200
0205 0210 0215 0220 0225 0230 0235 0240 0245 0250
0255 0004 0009 0014 0019 0024 0029 0034 0039 0044
0049 0054 0059 0064 0069 0074 0079 0084 0089 0094
0099 0104 0109 0114 0119 0124 0129 0134 0139 0144
............................... AND SO ON
even though i declared VAL & READING variables as WORD it only shows upto 255 and then restarts from 0
Isn't there some way out to to go beyond 255, my whole project depends on this.
Can someone help?
' {$PBASIC 2.5}
READING VAR Word
VAL VAR Word
EE_PTR VAR Word
EE_PTR = $000
READING = 0
READING = READING+5
NEXT
READ EE_PTR, VAL
' else
DEBUG CR
SKIP_CR:
NEXT
END
AND THE OUTPUT IS0005 0010 0015 0020 0025 0030 0035 0040 0045 0050
Can someone help?
WRITE EE_PTR, WORD READING
and see what happens.
Sid Weaver
Do you have a Stamp Tester yet?
· FOR eePntr = 0 TO $12C STEP 2
··· reading = reading + 5
··· WRITE eePntr, Word reading
· NEXT
Jon Williams
' {$PBASIC 2.5}
RS CON 4 ' Register Select (1 = char)
E CON 5 ' LCD enable pin (1 = enabled)
' LCD control characters
ClrLCD CON $01 ' clear the LCD
CrsHm CON $02 ' move cursor to home position
CrsLF CON $10 ' move cursor left
CrsRT CON $14 ' move cursor right
DispLf CON $18 ' shift displayed chars left
DispRt CON $1C ' shift displayed chars right
DDRam CON $80 ' Display Data RAM control
Line1 CON $00 ' starting address of line 1
Line2 CON $40 ' starting address of line 2
NoOfChar VAR Nib
ScreenV VAR Nib
FuncV VAR Nib
[noparse][[/noparse] Variables ]---
char VAR Byte ' character sent to LCD
index VAR Word ' loop counter
J VAR Word(1)
K VAR Word(1)
I VAR Byte
EditV VAR Bit
[noparse][[/noparse]keypad vars & consts]
btn VAR Byte
number VAR Byte
KeyEnter CON 10
[noparse][[/noparse] EEPROM Data ]---
DATA @0 ," WOODMASTER (INDIA) "
DATA @20 ,"Press ENTER to cont!"
DATA @40 ,"M/c Auto-</Manual->" ' SELECTION IS AUTO
DATA @60 ,"Program Mode- AUTO "
DATA @80 ," RUN-< / EDIT-> "
DATA @100," Program Number "
DATA @120,"Running... "
DATA @140,"Select Prog. Number "
DATA @160,"Program Mode: MANUAL"
DATA @180,"ON: 003 OFF: 003 "
DATA @200,"Running... HTR: ON "
DATA @220,"Running... HTR: OFF "
DATA @240,"Select Prog. Number "
DATA @260,"Up / Down 001 "
DATA @280,"Prog. Number 001 "
DATA @300,"Running... "
[noparse][[/noparse] Initialization ]---
Init:
DIRS = %00111111 ' set 0-5 as outputs
OUTS = %00000000 ' clear the pins
btn =0
NoOfChar=0
ScreenV=15
FuncV=15
EditV=0
' Initialize the LCD (Hitachi HD44780 controller)
PAUSE 500 ' Wait for LCD init
char=%00000011 ' Set 8-bit mode (1)
GOSUB LCDcmd
char=%00000011 ' Set 8-bit mode (2)
GOSUB LCDcmd
char=%00000011 ' Set 8-bit mode (3)
GOSUB LCDcmd
char=%00000010 ' Set 4-bit mode
GOSUB LCDcmd
char=%00101111 ' Set duty cycle 11xx = 5x11 matrix
GOSUB LCDcmd ' 10xx = 5x8 matric
char=%00000000 ' Display control mode
GOSUB LCDcmd
char=%00101000 ' 2-line mode
GOSUB LCDcmd
char=%00001100 ' Set display ON, cursor OFF, blink OFF
GOSUB LCDcmd ' 11CB -> C=1 cursor on, B=1 blink on
char=%00000000 ' Entry control mode
GOSUB LCDcmd
char=%00000110 ' Set cursor right, no display shift
GOSUB LCDcmd ' 01IS -> I=1 cursor right, S=1 shift display
char = ClrLCD ' Clear LCD
GOSUB LCDcmd
Start:
J(0)=0
J(1)=19
DEBUG DEC j(0)," ", DEC j(1)," ",CR
GOSUB GetChar
K(0)=200
K(1)= 219
DEBUG DEC K(0)," ", DEC K(1),CR
GOSUB GetChar2
END
LCDcmd: LOW RS ' enter command mode
LCDwr:
OUTA = char.HIGHNIB
PULSOUT E, 1 ' strobe the Enable line
OUTA = char.LOWNIB
PULSOUT E, 1
HIGH RS ' return to character mode
RETURN
GetChar:
char=Line1
GOSUB LCDcmd
FOR index = J(0) TO J(1)
DEBUG DEC index, " ", DEC j(0)," ", DEC j(1),CR
READ index, char ' get character from EEPROM
GOSUB LCDwr ' write it
NEXT
RETURN
GetChar2:
char = DDRam + Line2 ' move to line 2
GOSUB LCDcmd
FOR index = K(0) TO K(1) STEP 1
DEBUG DEC index, " ", DEC K(0)," ", DEC K(1),CR
NEXT
RETURN
This is my actual program. When i read them back the text it is reading wrong characters and lcd shows characters on wrong places
