Any Function similar to VB's CHR function?
----Is there a function like CHR that will convert a ascii character to a value?
I have a menu system that consists of a string of 20 characters Using a DATA string.·
Tx28· DATA·· "·····F257045 23· 150", CR,· 0
Tx29· DATA·· "·····25805E4 30· 132", CR,· 0
Tx30· DATA·· "·····25L8066 23· 150", CR,· 0
In this case, the first 12 characters are a product code, the 14th and 15 char are one parameter, the 17, 18 and 20 characters are a second parameter.· Both Parameters are numbers and need to be used in a formula.·
When I look up the product in the menu, I put these 20 characters into the scratch pad memory using the following:
LOOKUP (pulses), [noparse][[/noparse]tx1, tx2, tx3, tx4, tx5, tx6, tx7, tx8, tx9, tx10, tx11, tx12, tx13, tx14, tx15, tx16, tx17, tx18, tx19, tx20, tx21, tx22, tx23, tx24, tx25, tx26, tx27, tx28, tx29, tx30, tx31, tx32, tx33, tx34, tx35, tx36, tx37, tx38, tx39, tx40, TxP, TxP, TxP, TxP, TxP, TxP, TxP, txp, txp,· tx41, tx42, tx43, tx44, tx45, tx46, tx47, tx48, tx49, tx50, tx51, tx52, tx53, tx54, tx55, tx56, tx57, tx58, tx59, tx60, tx61, tx62, tx63, tx64, tx65, tx66, tx67, tx68, tx69, tx70], idx
idy = 0
·· DO
··· READ idx, char····················· ' Get next character
··· idx = idx + 1······················ ' Point to next location
··· IF (char = 0) THEN EXIT·······' If 0, we're done with block
··· DEBUG· char
··· idy = idy + 1
··· PUT idy, char
··· GET idy, char
· LOOP
This way, I have these characters in scratchpad locations 1 thru 20 and can pass them to and from the different 2k segments of my sx chip.
However, I need a way of taking a char like "3" and converting it to a value 3.·
Is there a function like CHR that will convert a ascii character to a value?· Then I plan on doing a bit of code like:
get 13, first
get 14, second
Temp = 10*CHR(first) + 1*CHR(second)
idy = 0
·· DO
··· DEBUG· char
··· idy = idy + 1
··· PUT idy, char
··· GET idy, char
· LOOP
get 13, first
get 14, second
· numVal = char - "0"
Jon Williams
