Wireless programming using the LinkMatik SE....
Hello, I have gone over to the Flexipanel web site and did a little reading· about the above.
In reading somewhere, and I cannot find it again, I see that I will need a device that plugs into the USB port that will communicate with the LinkMatik SE.· What/where is this device available? (I assume it is some sort of Blue Tooth device.)·
Also in reading, and again I can't find the page again (it was a late reading night) ...it said that the USB port transceiver device that is used to communicate with the LinkMatik SE will not work with Windows XP because of something called a "Pass Key".· Is this true?
Thank you for your reading time and your time to answer..
Deno
Deno
Parallax did say that they were aware of the market interest for wireless programming and debug, but did not give any indication as to when a product might be available.
Jon Williams
Deno
