Good pressure sensor for lake water level?
Hi - I want to make a logger that records lake water free surface height. What I've done in the past is to use a 4" PVC pipe with end caps as the housing, mount a 4-volt output, gauge pressure, pressure gauge with a dynamic range of about 200" of water. The Mouser catalog has a PC board version for about $70 with reasonable linearity (Allsensor makes it). I would bring in the water pressure via tygon tubing filled with silicon oil. Electrical connections would be made through a water-tight feed-through connector. Has anyone else made one of these? When they are placed in the ocean they become tide gauges............................................Pete Smith
Honeywell makes a large variety of pressure sensors in different configurations (pressure, gauge, differential) with both amplified and unamplified outputs. If memory serves, they run 15 to 30 dollars each in small quantities. Check out:
http://content.honeywell.com/sensing/prodinfo/Pressure/
Motorola (now called Freescale) also produce a line of pressure sensors in a bewildering variety of configurations/outputs/formfactors. Check them out at:
http://www.freescale.com/webapp/sps/site/taxonomy.jsp?nodeId=01126990368710
I have used pressure sensors from both manufacturers in microcontroller designs, and found them to work equally well.
Good luck!
peter
Peter C. Charles
Director, Research and Technology
CyberBiota, Incorporated
Peter.charles@cyberbiota.com
http://www.cyberbiota.com
