Relays and Solenoids
Hi alll,
Are there any relays and solenoids that would work better with the BS2 ?·
Can anyone recommend any ?
John
John
Jon Williams
By using 40K in resistors into the base of a 547B transistor, biased with a 1meg resistor, you can use most common relays. Remember to use the two diodes around the coil to prevent AC current generation. This will only require 2.4 volts @ 4ma on an output from your stamp which will keep it running cool for the long extended duration.
Greg
I now have a ping sensor circuit with an adjustable detection field (distance) using a pot and lighting up an LED when something is in the field.· That's basically 1/2 my circuit.
Specifically for the last 1/2, I'm looking to ring the alarm bell mechanism from an old alarm clock for the duration that the ping sensor is detecting something in the field.·
Anyone have any ideas ?· Is there maybe an electronic set of similar bells ?· I played around with the notion of doing this by playing a WAV file of the sound of the bells.· But the guy I'm building this for wants the actual bells to be rung.
John
