Connecting two SXs together
I have a project that I will be using 2 - 3 SXs together. My questions is if I us an output from one SX to control the input of another, do I need to pull that·pin low or high, or will SXs keep the lines from floating?
I know on a switch you never really want a pin floating so you pull it low or high w/ a resister (10K??). But I have never connected two uc together like this.
Also, in my design each SX will have it's own 7805. All will have a common ground. Is there any problem with this?
Jim fouch
Jim fouch
·· In the case of the SX Chips sharing ground but each having their own regulator, not a problem. As for the I/O lines.· As long as the I/O lines from one are outputs, and they are connected to input lines on another, you won't need pull-up/down resistors, as the lines that are output from the driving device will hold those lines high or low as needed.· Now if it's bi-directional, you may want to implement something.
csavage@parallax.com
