Is it possible to program a stamp wirelessly and to....
receive DEBUG data wirelessly.
Several of my stamps are in the field, so to speak, and from time to time I find it is necessary to reprogram the eeprom.· This reprogramming is only because I have figured out a better way to (cleaner way) to write the code or I just want to change the timing of something.· Usually, these stamps are in a watertight housing which requires at least 30 minutes to take apart and then another 30 to· put together.· Plus having to take the lap top out in the elements.· Hard to see the screen in direct sunlight. That sort of thing.
I have made up a long programming cable, about 50 feet, which works, put wouldn't it be nice to just take your laptop from inside the car or wherever and change the code wirelessly, or monitor the stamps operation with well placed DEBUG statements. (Transmit that air temp back to the DEBUG terminal.
If possible, I could see where I would incorporate a wireless transceiver right into the design of the system.
It would be nice to tie this transceiver right into the programming port of the Basic Stamp.·Pins 1,2,3,and 4. ·I am sure this could be done with some of the RF modules I see in NUTS and VOLTS by someone, maybe?
Has anyone done this, and if so, would appreciate a link to the devices that you used to do this.·
Deno
Deno
P.s. Parallax Product Development Team - I think there would be tremendous interest in a Parallax supported product that does this... any ideas on when we can expect such a product?
Jon Williams
Sid Weaver
Do you have a Stamp Tester yet?
