74hc595 output current
I am making a circuit using a transistor for a switch, but I need to know how much current the 74hc595 shirft register can output in order to determine what type of a transistor to get.. DOes anybody know this?
How much current will the transistor switch? If you are doing simple LED's with a common 2n3904 there will be no problem whatsoever using proper resistor values.
Ken
Jon Williams
