Recommended Flexiforce sensor mounting?
I'm about to use the Flexiforce sensor to measure the amount of liquid in a barrel.· I'm only looking for a rough gauge of how much is left, let’s say 10 divisions. IE >90%, 89-80%, 79-70% etc.· The barrel will weigh in at about 160lbs when full.· My current idea is to build a platform with four legs and under one of these put the flexiforce sensor.·
This post a while back shows the weight around the active portion of the sensor. http://forums.parallax.com/forums/default.aspx?f=10&m=79076&g=79400#m79400
My thinking was to put the weight on the active portion.· What would be the correct way to use this thing??
pressur on one leg.
73
spence
square leg
|·······| XX |
|······ | XX | Flexiforce
The main point I wanted to make with that post is for the readings from the sensor to be reasonabably repeatable,· some attention to applying the force in a repeatable manner is needed.
The picture may not show well, but I had a clear plastic ruler on top of the sensor, then the weights on the ruler. This was done in an attempt to get a relatively uniform distribution of weight on the sensor.
Than as you saw, there was a different reading when the same amount of weight is used, but a little off center.
I·think the three legged platform idea should work.
Ken
In the case of 4 legs, it is possible to spend many hours and shims getting just the correct height on each leg for the leg on the sensor to give a reasonable output.
73
spence
Thanks for the help, that clears it up. I thinking that I will have blocks around the barrel so that it's centered on the platform each time. Mabey even a level on the platform to verify that things are ok.
Orion is not concerned with actual weight, just a proportion of full, so the sensor output can easily be correlated to 90~99%, 80 to 89% and so on.
Ken
Tracy Allen
www.emesystems.com
This may be of some interest to any one that has the sensor.
http://www.tekscan.com/pdfs/FlexiforceUserManual.pdf
