Segway type balancer...
Has anyone been able to use a MEMSIC sensor to make a two wheeled "balancer" with a BS2 or BOE?
I saw it was done with a Lego mindstorm kit.
·· The height (Well, center of gravity) of the bot as well as the type of drive system will also affect the balancing system.· So far steppers have been the most widely used motors I have seen for this kind of thing, but that doesn't mean a DC motor won't work equally as well with proper design consideration.· Servos may be too slow unless you have a well-balanced bot.
csavage@parallax.com
You say 'two-wheeled'. So, I imagine that you have seen the two-wheel contraption that used two IR distance measuring devices to keep upright. It seems to be able to adapt to radio control of movement.
The problem with the pure optically balanced design is that it cannot handle sloped ground.
Assuming you combine both the IR sensors from the optical design and the Memsic, you could have the Memsic benchmark vertical within a given limit [noparse][[/noparse]one that would allow the robot to keep moving] and have the IR sensors handle the swing [noparse][[/noparse]or plugoid motion] by adjusting one to the high side and one to the low side.
I would really love to build one of this and have it r/c controlled.
Above all put the batteries low as they will give you the lowest center of gravity and allow you to build for more height. I don't think steppers are as good as geared-reduction DC motors with big wheels. They have some special problems, such as pulsing at certain speeds. Also, I think they use more power.
Bicycle trainer wheels are very cheap and light. I have my eyes on a 18 long rectangular wire basket for a light weight chassis. It just need to get the wheels adapted from 1/2" holes to a 6mm motor shaft.
Anyway, both are quite eye catching as they seem to defy being mundane machines.
G. Herzog in Taiwan
From the great customer applications page .....
http://www.parallax.com/html_pages/resources/custapps/app_bway.asp
Can it handle hills and slopes?
That is why you may need the Memsic or more than one Memsic - one for vertical, possibly another for acceleration control.
The article actually states that they want to do more research about this.
Additionally, the photos show the batteries at the top end which makes the programing and design more of challenge as the center of gravity is higher.· It also demands more power to maintain.
G. Herzog in Taiwan
BEst Regards
Manuel C. Reinhard
I was thinking that the balancing was centering around the wheel axle. But if the two masses are coupled and equal, the center is halfway inbetween.
Very interesting. I'll have to find the time to build my own version. I have the Memsic and I just got 6 Sharp IR sensors.
There is a lot of mechanics that should be discussed more in robot design. It can't all be done with big motors and faster processors.
G. Herzog in Taiwan
