Self leveling platform w/ a memsic 2125 and servos
I am new to the basic stamp but I am hoping for some guidance.
Has anybody tried making a small self leveling·platform using a tilt sensor (memsic 2125) and servos? Would I need to use stepper motors to get·a level value returned from the memsic 2125?
I'm thinking of using logic similar to the following:
If the value returned by the memsic 2125 on the x axis is greater than·800 then the servo will rotate the platform so many pulses in·a direction until the memsic returns a level value.
If the memsic 2125 was to return a value less than·800 then the servo would rotate the platform in the opposite direction.
The Y-axis would be handled in a·similar manner. Any help or direction to literature on the subject would be appreciated.
Thank you
Harry
Thank you
Harry
Jon Williams
So you're saying I should be able to extrapolate the values from the memsic in to pulse values for the servos to make a "near-direct" move to level?
Thank you
Harry E. Edmondson
Jon Williams
