EEPROM error and 5" floppy drive
Hi!
Basically 2 irrelevant questions.
1)Several times on attempting to download a program, I have recieved the error "EEPROM Verify failure" and the editor refused to
download. Upon a reset of the Stamp, the download worked fine.
2)This has nothing to do with the Basic Stamp, but I'll ask anyway... I have an internal 5"floppy drive and a whole pile of disks for it
(120, to be exact). I'd like to test the drive and check what's on all those disks, but i have no free slot. My question is if there is a
way toconvert the IDc output plug of the drive to rs232 or parallel?
There is a diagram of the IDC floppy pinout at http://pinouts.ru/data/InternalDisk_pinout.shtml
Rafael
Rafael
Jon Williams
Define "free slot".
Are you talking about a cable, case space.....
If you are thinking of converting it to an external floppy then I would find another way.
In that case you would want to lean towards Parallel.
- - - PLJack - - -
Perfection in design is not achieved when there is nothing left to add.
It is achieved when there is nothing left to take away.
Rafael
Rafael
Probably not going to happen with a 5 1/4" drive.
In any case you would need the drivers to operate it externally.
I would say your best bet is to take the floppies to your local computer store and have them copy the data over to 3 1/2" floppies. Or CDROM.
- - - PLJack - - -
But that's rather stupid, caus' a year ago when we moved here we had a computer that did have case space and connections, but we got rid of it because it was too slow (~800 Mhz). Now I'm stuck with 2 of those 5 1/4 drives and I can't use them!! GRRRRR!
I guess nothing I can do, thanks for the advice.
Rafael
I remember seing parallel port floppy drives, mainly for the 3.5 floppies, I wonder if it would be possible to hook up
a 5.25 to one of these old units???
Bob N9LVU
Where did you see the parallel drives?
Maybe they have something similar!
Rafael
Rafael
I used to have one a while back, now I know they make them for usb, there are some on ebay going for a few bucks right now...
Mine was originally used for laptops... Its been a while, I would just hook up the 5.25 to a cable/power on pc and transfer all the files over to
another media, that way you don't have to fudge something together.
I also remember a floppy adapter cable to external floppy in case, but you would need shielded cables/adapter plugs.....
I also have 2 of fthe 5.25s (360K, 1.2M) and a dual (1.2M 5.25, 1.4M 3.5) combo drive sitting in the cabinet right now....
Bob N9LVU
Rafael
Most of the usb 3.5 floppy controllers are custom built and mounted directly to the floppy drive, however, some of the older models had a bridge chip that converted usb to a floppy interface, that was then connected to a standard 3.5 floppy, if you can find one of these, you can use it as an interface to your 5.25 floppy drives, then only problem is that the floppies you have must be 1.2 M (HD) or better I do not think that they supported (SD/DD) 360K 720K densities...
And you must have the correct driver, and if that old, would be a DOS driver, and a DOS file transfer..... Also if you need to save the data, do it soon, as magnetic data on floppy discs ten to weaken with age to the point of being unuseable....
Bob N9LVU
Rafael
