IR Wheel encoder - reliabilty
Hello all,
Does anybody have any experience, ideas?, on making an IR wheel encoder work more consistanty.
The encoders & wheel disks are these:· http://active-robots.com/products/motorsandwheels/wheel-encoders.shtml
(the top two products)
When the are setup on each wheel, one returns a fairly consistant set of pulses (0-5V) and the other widely varies.· They are both mounted under the body of the robot, at nearly equal distances and positions relative to the wheels.· Using the CPU.count method on the Javalin to count pin transitions.
Help?
James
Help?
James
Greetings from Germany,
G
Thanks for the idea!
The tech support guy from www.roboticsconnection.com (manufacturers) emailed me as well, turns out the mounting distance 4mm was too far.
Ideal is 1.5 to 3mm appearently.
Cheers
James
