Serin sx28 — Parallax Forums
Serin sx28
sumguy16sumguy16 Posts: 21
edited 2005-07-12 14:52 in General Discussion
I need two pass to variables to an SX28 via SERIN. I'm using a bluetooth module so I only have one RX. The variables I know can only be one byte at a time so I can have the value of the variables be between 0 and 255 , not a problem. I just need a solution that the SX28 will know the difference between the two variables. Any ideas?
Adam
    edited 2005-07-12 12:13
    That's actually quite simple: create a subroutine to do your SERIN and then call it twice.· The SX28 runs fast enough that it will be able to deal with the variables in between transmissions.· As of version 1.3 you can use subroutines like functions in other languages:
    · myVar1 = GETBYTE
    · myVar2 = GETBYTE
    Here's the code for the GETBYTE subroutine:
    GETBYTE:
    · SERIN Sio, Baud, temp1
    · RETURN temp1
    Jon Williams
  • KenMKenM Posts: 657
    edited 2005-07-12 14:33
    Jon or anybody,
    I am not familiar with "use subroutines like functions"
    Is the end result that the subroutine is called and temp1 is returned to myVar1 and the same with myVar2?
    Thank you.
      myVar1 = GETBYTE
      myVar2 = GETBYTE
    GETBYTE:
      RETURN temp1
    Ken
    As of 1.3 SX/B can pass values back via W. When used like the example above, W gets loaded with temp1 at the end of the subroutine and then goes back to the caller where W is moved to the target variable. I thought I had made a big deal about this feature when it was released... clearly nobody pays attention to me -- unless I make a mistake! tongue.gif
    Here's the SX/B compiler output of a little test that shows the mechanics:
    Start:                           ;Start:
      MOV myBits,#$AA                ;  myBits = $AA
      MOV __PARAM1,myBits            ;  myBits = INVERTBITS myBits
      CALL @__INVERTBITS
      MOV myBits,W
      JMP $                          ;  END
    INVERTBITS:                      ;INVERTBITS:
      MOV temp1,__PARAM1             ;  temp1 = __PARAM1
      MOV W,/temp1                   ;  temp1 = ~temp1
      MOV temp1,W
      MOV W,temp1                    ;  RETURN temp1
      RETP
    Jon Williams
    Post Edited (Jon Williams (Parallax)) : 7/12/2005 2:59:04 PM GMT
