Pulsout Command To More Than One Pin
I have a need to send a pulsout to two·pins at a time. I want pulsout to occure simultaneously on both pins. I know I can do it with external circuitry using one pulsout, but want to do it within the Stamp.· Is there a program algorithm you recommend?· I tried the following test program with no luck.· Only P0 would go high.
DirL = % 00001111
x var OutA
loop:
·pulsout x, 60000
·pause 3000
goto loop
Regards,· Mike Marks
DirL = % 00001111
x var OutA
loop:
·pulsout x, 60000
·pause 3000
goto loop
·· While you cannot PULSOUT to more than one pin at once, you can effectively PULSE more than one pin at once on a port by doing something like:
csavage@parallax.com
LOW P0
LOW P1
LOW P2
LOW P3
Main:
OutA = %0011
PAUSE 60
OutA = %0000
PAUSE 3000
GOTO MAIN
pulsout anypin, 250
The BS2 timing increment is 2us so 250 would = 500us.· This is just a dummy command to use up a little time so pick a pin that is not being used for anything.
Sid Weaver
Do you have a Stamp Tester yet?
