SX-ethernet/network
hello,
Is there a module that connects the sx28 with the use of an ethernet port to the Internet?
I saw there is a board for the sx52 avaible, but is there a module for the sx28?
Kurt
Kurt
Post Edited (Paul Baker) : 7/13/2005 12:53:12 PM GMT
I would say a module would be the only way, in which case they are probably several vendors.
BTW, just a fun bit of trivia... Scenix even once made an internal demo that had an SX28 bit-banging ethernet on an SX28. It worked, but needed to be run at 100MHz @ 6V (+/-1% max!). It had a huge heatsink that was still burning hot!
What did you have in mind?
Ryan
The purpose of the Ethernet module is that i can send and receive some 8 or 16 bits data from/to the sx28 with the use of Telnet software.
I wrote a program (not tunned up), with the use of VP lib, and datasheet of the ds1620, to simply read out the temp of a tempsensor and sent it to a serial display and to a laptop.
So when i am not home i am still want to check the temp in my greenhouse, and switch on some cooling, or do some other stuff.
Kurt
