OWOUT command
                    Hello,
I'm trying to make a domotic application with a Basic Stamp 2p24 and for this, I'm using the command OWOUT and OWIN with Dallas componend such as DS2405 and DS1820. For the DS2405, I try to use the matchRom command, followed by the 64 bits of the code of the componend, but It doesn't works if I'm using variable for that code. It only works with the direct characters written in hexa (or other), but not with a variable wich has this character.
This works : OWOUT OWpin,1,[noparse][[/noparse]MatchROM,$05,$B3,$82,$00,$00,$00,$00,$DF],
but this doesn't works : OWOUT OWpin,1,[noparse][[/noparse]MatchROM,HEX2 code1,HEX2 code2,HEX2 code3,HEX2 code4,HEX2 code5,HEX2 code6,HEX2 code7,HEX2 code8] and I'm sure that the variable code1=05 etc...
Can you help me?
Thank you.
Julien Hordies
P.S:sorry for my english, but I'm Belgian.
Can you help me?
Thank you.
Julien Hordies
· OWOUT OWpin, 1, [noparse][[/noparse]MatchROM, code1, code2, code3, code4, code5, code6, code7, code8]
And here's another trick if you've defined code1..code8 in order in your declarations:
· OWOUT OWpin, 1, [noparse][[/noparse]MatchROM, code1\8]
Jon Williams
It works...
